Hello,
I have a AC410S that is having issues being able to climb up my hills.
At the outset, it can do it fine. But some time later (30 minutes or so on a warmish day), it won't. I have to move into 1st gear.
The tires are not slipping, and I'm not hearing/feeling anything "abnormal" from the tractor. If I move the "control lever" to the Reverse position (with clutch engaged) and then back to the Forward position, I feel a bit of grab, but it fades very quickly.
In perusing the forums, I did see someone in another thread mention a similar issue, stating: "The only tractor I had that didn't climb that hill was an old Dynamark with a worn out hydrostat,after it got hot (half hour or so) you couldn't even get it to move on FLAT ground!...."
So, I presume the "hydrostat" the poster mentioned is the "hydrostatic transmission." My Shuttle does not have that. So I'm presuming my issue is related to drive belt tension.
Would some kind soul be willing to help direct me...presuming I'm even on the correct path?
I note that I do have in front of me the "Operator's Manual," and am looking at Figures 24, 25, and 26, which I presume represent the work areas I would need to find myself to fix this issue.
Thoughts?
Thank you.
Thoughts?
Thank you.
