1 - 11 of 11 Posts
Still Plays With Tractors
I got back to working on the massey crawler project. I bought a wheel horse dozer blade that had a long frame on it. I built a bracket on the rear end of the crawler to mount the blade frame. I had planned on using a hydraulic unit off of an old gilson tractor that i had put the pump was shot. I bought an ATV 12 volt winch and mounted that to the front to raise and lower the blade and it works like a charm.
I took it out in the crushed rock and the dirt to try it out and it pushes just like the real dozers do!
I have to build the back rest , recover the seat and then paint it yet but it does work!
Retired Aug.31 2007
That is a tuff looking little tractor.
Tractormike that is one cool piece of equipment, really nice job. Can't wait to see it painted.
I bleed M-F red
It looks good. Nice job.
Where do you put your legs and feet when you are using that thing?
You can not see the operators space in those pictures but there is room for your feet ahead of the seat and between the tracks. I enclosed the operators platform so your feet couldn't get caught in the tracks. Here are a couple of pictures that show that better.
Hi
That is really nice. There must be a lot of hard work hidden under the body. How is the track drive powered?
Brian
USMC
Looks great and sure would like to see some video of it in action. slkpk
Discussion Starter #11
To answer a couple of questions, the tractor is built out of a Pennsylvania Panzer frame with Massey Ferguson sheet metal on it. The Panzer tractors used a narrowed Dodge rear end and used a 3 step pulley system for their tranny. I modified a set of hydraulic trailer brakes to work on this rear end and use 2 Ford 1966 Mustang single circut master cylinders hooked up to the yellow levers to steer it. The front wheels are built on a sliding frame and are individually adjustable to tension the tracks. The tracks are made from 6 inch wide belting that is used in balers that make the round hay bales. I bent the tire guides to fit the tires and bolted through the grousers, track and then the guides.
I'll post a couple of early build pics.
1 - 11 of 11 Posts
