1 - 10 of 10 Posts
Acquired a GT5000 27HP B&S a few years back, it's tunes, cleaned and so on. Every once in a while for no reason the motor will go up and down as if it was going to run out of gas then it's ok for days or a week or more.
I did notice other then when I first start it up there's never any gas in the gas filter you will occasionally see some vapor but that's it. Any thoughts?
maybe the govenor? Not unusual not to see much gas in a filter on a tractor. Smarter guys will be along:thThumbsU
To add to this when it does this if I pull the choke out just a little maybe 1/4" it runs fine then i can slowly push it back in. Forgot about that.
Sounds like you're having a fuel delivery problem to me. But, it's intermittent. I'd replace fuel filter and check the tank for gunk. I had a tractor that did the same thing except it was constant. Removed carb, cleaned, same problem! Ran pretty good with the choke about half out. Anyway, I used the little funnel/fuel line trick (by-passing the tank) had a buddy pour gas in the funnel while I started it. Ran perfectly, no more wandering. Found the fuel filter and tank fuel screen plugged up somewhat.
Water is my guess. It bogs a bit until it gets though the system. Plastic fuel cans in areas where there are 20 degree temperature shifts will get condensation running rampant in your fuel jugs. I've had a lot of problems with that with the high humidity this summer. It's a big problem with plastic fuel tanks in small engines left outside too. Happens with metal fuel tanks/jugs too but it's not usually as bad.
Condensation? What's that? We don't get moisture in the Southwestern states... much! lol Good thought though...he'd find out pretty quick by by-passing the tank and fuel filter.
Discussion Starter · #9 ·
Hey Curly69...you ever find the cause of the surging??:bump9:
No not yet. Took the carb apart but it back together and it does the same thing. I do have a question for the more knowing here though.
It seems the intake manifold is warped not sitting flat against the engine and the orange O rings are flat. It's only plastic and kind of cheesy at that. I'm going to hunt down some new o-rings or fill the groove on the plastic manifold with some high temp. silicon and flip these over.
I had the same problem last year until I rebuilt the carburator. There is a brass needle valve that controls the amount of fuel into the manifold. The brass needle was sticking. The rebuild kit that I bought had a plastic one. Since then, no problems.
1 - 10 of 10 Posts
