I hope this is the correct place for this post. I have a Z425 54" that I put new blades on about 3 cuts ago. I noticed that a striping effect started to occur, and after closer examination, realized that the far left blade seems to be cutting a good bit lower than the rest of the deck. I removed the deck and sure enough, the left blade didnt align with the center blade. The center blade and right blade did align. I swapped the left blade with the right blade to see if the mismatch followed the blade and it didnt....it stayed with the spindle. So now knowing that it is spindle related.....what could it be?
