1 - 1 of 1 Posts
Precision Application
Turbo TeeJet® Induction Flat Spray Tips
Features
  • 110º wide angle, air induction, tapered flat spray tip pattern based on the patented outlet orifice design of the original Turbo TeeJet nozzle.
  • Patented orifice design provides large, round passages to minimize plugging.
  • Depending on the chemical, produces large, air-filled drops through a Venturi air aspirator resulting in less drift.
  • All polymer construction for excellent chemical and wear resistance.
  • Compact size to prevent tip damage.
  • Removable pre-orifice.
  • Ideal for use with automatic sprayer controllers.
  • Wide operating pressure range: 15-100 psi (1-7 bar).
  • Automatic alignment when used with 25598-*-NYR Quick TeeJet cap and gasket.
Typical Applications
  • Excellent for spraying post-emerge systemic herbicides.
  • Very good for spraying pre-emerge surface applied herbicides.
1 - 1 of 1 Posts
