1 - 3 of 3 Posts
Does anyone have any familiarity with the operation and shifting of a 6 speed +R , Tuff Torq K 210 A ( Gear ) transaxel that would typically been in a 1993 - 1994 Simplicity 14 GTG, 1692024 ?
I'm having difficulty with the clutch pedal that also activates a swing arm on the transaxe (Left side ) and also adjusting "Neutral" for the speed selector / shifter. ( Right side )
Discussion Starter · #2 ·
0kay , I have the "Simplicity Service and Repair Manual" , manualslib.com/manual/1442342/Simplicity-1691682 .
I'm needing information more from the "Simplicity 0perators Manual".
Proper shifting procedure. Do you need to clutch to shift ? Be at a dead stop ?? Be moving??? Partially Brake ????
Dahhh ... !
manualslib.com/manual/153199/Simplicity-1691996
1 - 3 of 3 Posts
