I found a set of the front HDAPs that I had mounted last week and one of them loses about 2 psi of pressure overnight. I took it back to the place that mounted the tires and they couldn't find the source of the leak, so I had them put a tube it. My question is if the other tire holds pressure fine, is there any reason to have the other tired tubed also (other than insurance against it too developing a leak)? I saw another member had a similar issue and tubed them both because it changed the shape of the tire. Was wondering if the front tires are slightly different, can that throw off the deck leveling by a bit or cause some other problem? Thanks.
