1 - 10 of 10 Posts
I need to replace the rear tires on my '49 8N. The existing tires are tubeless and I am wondering whether or not to add tubes when I replace the tires.
My preference would be not to add the tubes since plugging a leak (Lots of thorns out on the ranch) would be easier than pulling and patching a tube, but I am wondering if there is a compelling reason that I am not thinking of to add the tubes.
Advice/thoughts would be welcome.
I'm with Steve on this, have you considered having the tires foamed and then thorns are not an issue.
Foam in tires adds a lot of weight and sure stops the problem with flats but they ride like solid steel wheels. They also seem to have less traction as they don't flex to grab ahold. Least that's what my limited experience with them says.
Mike
The voice of reason !
Mike
I didn't think adding no flat foam to a tire added that much weight to it, does it really ?
I misunderstood. I thought you meant filling them with the ridged foam they use in some fork trucks and backhoes. I'm not familiar with the "flat foam", never used it but have used Slime with good results.
Mike
life is good
The only problem with putting tubes in a tubeless tire is the ridges inside the tire tend to pinch the tube. This causing flat tires/tubes. Have had this happen more than once. Dad runs tubes in our chore tractor and we go through a tube every 6 months or so.
1 - 10 of 10 Posts
