1 - 7 of 7 Posts
What is that little screw on the bottom of the carb, buy the drain plug called, and are they including in a rebuild it?
Tractor Restorer
There is a 1/8" Pipe plug on the bottom of the carb which I always replace with a radiator drain **** to make it easier and faster to check for fuel flow at the carb and to drain the fuel out. There is also a slotted screw that plugs the opening that the factory used to drill the port for the main jet. Some of the models had an adjustable power jet. They are not typically included in the kit.
http://l-36.com/carburetor.pdf
HTH
-- Mark
Tractor Restorer
I got mine at ace hardware. Use some aviation gasket sealer ( formagasket #3 -permatex) to seal it. I got a 8-32 x 1/2" Round head
screw -- brass and a brass flat washer had to cut the screw off and
it works for now -- no leaks.
-- Mark
I wanna make sure we are talking about the same thing, By the 7/16 headed drain plug there is a little tiny screw and you can replace that with a raidator pip-****?
Tractor Restorer
No you can replace the big plug with the radiator drain
the iddy biddy screw is 8-32
Im guessing ace hardware would have one of them too? the 8/32 screws? I just normally go to the junkyard and grab another carb for 10 or 15 bucks, thats why i ask.
And thanks for the help!!!!!
1 - 7 of 7 Posts
