1 - 6 of 6 Posts
Hi all,
I'm trying to identify a tractor for my father. It is an older (1970-80's?) John Deere tractor with a Kohler engine. The plate on it states 10643 TYPE and the seril # is 278415M.
(I have the numbers from the Kohler if that would help also).
He's having an issue with a belt having too much slack and rubbing and I couldn't find any info without knowing the model.
thanks in advance for any info,
Mike
· Three of my friends
Have a picture?Any numbers on the hood,
· Deceased April 2016
Hi all,
Mike
Hello Mike
In researching your John Deere it shows to be a 1973 John Deere 110 with a K181 Kohler Eight Horsepower single cylinder engine in it. This style Tractor had a fender pan on it unlike the earlier one's that had two seperate fender's on them. They were a gear Transmission tractor with a Variator on them to increase ground speed and most were hand lift style but they did offer an Optional Electric style lift for them. They made a mowing deck, front blade, and Rear roto-tiller attachment for them. I hope this helps, Hammerdown
Hello Mike
thanks for the info and this should clear things up for my father.
· Diesels are awesome!
I have two '73s, and they are both strong tractors. Neither has run in a little while, but I got the 10 hp 110 running this weekend, and I forgot how much 10 hp really is. The varator is a tough system, even though you wouldn't believe its belt drive. The post-'71 tractors have the 1 inch diameter spindles, so it will take a little more wear and tear on thr front end.
1 - 6 of 6 Posts
