I scored this Horse off the side of the road for free the other day. I got it running well but I'm having problem with the drive. The belts are slipping unless I hold down on the engagement lever. I havent had a chance to look at it too closely but I did notice there seems to be slop in the main drive pulley at the trans. Looking at the IPL, there is only a snap ring that holds this on the shaft so it seems one would expect to see some movement there but how much is too much? I'm thinking this might my problem along with stretched belts. Anyway, here she is. It is a January of 1977 model with 6hp Tecumseh.
Great find! I wish my neighbors would throw away such useful things.
I just replaced the belts in my Pony but haven’t had a dry enough day to till yet. I bought new belts last year but wanted to get the last bit of life from the originals. Reverse kept slipping off and I discovered it had finally cracked through the V to the fabric.
I don't recall any slop in the transmission drive pulley. There is some end play in mine, maybe 1/16"-3/32". If you have radial play there, you'll need to take it apart and see what's worn. I'd expect you'd have oil leaking in the area.
Check the engagement lever adjustment block and move down as needed. It needs tweaked as the belts wear. The manual is here on this site as a sticky. Adjustment procedure begins on page 98.
If you do need new belts, the Oregon 75-685 belts are a perfect fit!
I would also recommend checking the lever adjustment block and moving it down slightly to take up slack in the belt. I'm not sure if everyone's horse is like this, but mine is very sensitive. 1/8 inch moves are typically plenty to get the job done.
" The belts are slipping unless I hold down on the engagement lever."
The 1977 year model I have uses one belt. Yes, it does have double drive and double driven pulleys, but it is to change speeds by changing which pully the belt is on.
Thanks guys. This is definitely the setup that uses two belts. I tire it apart tonight. The pulley bore is worn hour glass shaped and the key and key way are worn badly in both the pulley and the shaft. Really appears I need a new trans shaft and a pulley.
Not sure I want to put that much into it just yet so I think I'm gonna try to put a new key in, get some new belts and see how that does.
Serial number I have written down at home. It dates it as January 1977, I will post it after work.Where would I find a model number? All the original decals seem in place but I do not see a model listed anywhere.
Serial number is 254784.
Again, dont see any model info anywhere but I'm assuming it's a horse 1 based on the info I've been finding.
6 hp tecumseh HH60
6 hp tecumseh HH60
Hi! I recently got a Troybilt tiller and am trying to figure out what the date of manufacture and the model is. It has a clinton engine with an oil bath air cleaner on it. That alone made me buy it! Not sure if it's pony or horse but I think it's too small for a horse. The number on the top of...
Just scored a NOS Troy Bilt blade for $60. Came with both brackets and even the bracket mounting bolts that attach it to the bumper. I was checking these blades on ebay and they're asking north of $300. Crazy.
I am needing some engine parts for my 1970's Troy-bilt tiller that I am restoring. The engine is a Kohler K161T. The flywheel has 3 adjoining fins broke off?? Do not know how? But I would like to find one. Ebay has them online but they do not have the magnet inside. I also need to replace the...
A forum community dedicated to all Tractor owners and enthusiasts. Come join the discussion about specifications, modifications, troubleshooting, maintenance, and more!
