I hope it's fine I post this here.
Last Friday I purchased a T-B GTX20. It appeared to be decent deal. The tractor came with a rototiller, snow blower, snow plow, winter cab attachment all for $2300. It's a earlier model with the Kohler M20QS. the guy admitted he knows nothing about these tractors. It came with his house and he wanted a zero turn as it's faster cutting the grass. He said he replaced the head gaskets and the float on the engine. The engine starts right up and is very smooth from low midrange throttle to high. However, the engine slightly backfires on low idle and jerks a little. The hydrostatic drive runs smooth the only issue with hydraulics so far and he told me about was if you put the mower deck drops back down overnight, which I found to be the case. Would that be a hydraulic cylinder issue or a hydraulic valve issue? Also he mentioned the main fuse blows when you try turning the headlights on and the cruise control he could not get to work. He thinks is all related. When I got it home, I tried the cruise. In the on cruise position the light comes on but wont hold the peddle. If I hit the cruise reset the light gets super bright as if it's getting extra voltage to the light. Then sure enough, when I turned on the headlights none of them came on, but shortly after the engine started sputtering and just died. I've attached picture of the fuse that blows and a wire I found that looks like a repair going to the PTO possibly? Now, I can turn on the PTO and it runs just fine. Any ideas on where or how to start trouble shooting the electrical issue? Last, I dunno if this is an issue or not. This is my first Kohler opposed twin. For whatever reason after changing the engine oil (SAE 30) and Kohler oil filter. I noticed a decent amount of air blowing out the dipstick hole. I thought right away I have blowby due to bad rings? However, some posts I looked up said this is normal with opposed twin kohler engines and others have said it's not normal. Anyone with the M20QS notice if they have air coming out of the crankcase to be noticeable? When I installed the new spark plugs the old ones appear to have a clean burn and there was no oil on the filter or in that area. So that's a little confusing. I have a cylinder compression gauge coming in today. I see what it reads. I also changed out the trans fluid as the old was a non-transparent black with TS universal tractor hydraulic / trans fluid and a new Napa 1416 filter. The steering seems a little harder than the GTX-16 I have, not by much. Dunno if that's normal.. The unit has about 680 hours on it...
Any advice is greatly appreciated...
