It probably won't run with a 112 carb. Way to much fuel and not enough air restriction.
I'd clean your 110 carb and reinstall. That will work even if your idle jet is still clogged.
Check for spark, do a thumb test for compression. And crank for 30 seconds trying to get it to go. Then check the plug for unburnt fuel.
Most often I find a bad plug or coil on dead ones I get. I've also had stuck points on one.
