Transmission ?
2494 Views 10 Replies 4 Participants Last post by  rentalken
Have a huskee 21hp garden tractor 2 speed rear end is there a way to check fulid level? What type of oil- grease goes in to it. More info that i have the tranny is a model 618-0301a Thanks Ken
1 - 11 of 11 Posts
What's the tractor model and serial number, Ken? Most likely 90wt, but I'd like to pull the manual so we know for sure.
It uses lithium grease like mine, 90wt might work. Mine is an 845 GT model number 146S845H088 it has a High/low like his only difference is mine has 18.5 hp in it.
32 oz of Shell Darina grease if it's the same as Mtd Snow Plow's. DO NOT USE 90Wt.
Could'nt find a model or serial number on the unit anywhere when i got it
I know the engine is 1999 best i could come up with for model is
14AJ848H131 Thanks
Thanks how do you put it to the tranny?
I belive you have to open it up or there is a small rubber seal on the top, you can take that out and fill it up, but you should drain the old grease out. I've never done it but I think I might give it a try.
Shell Darina grease is more akin to a 300 weight gear oil, so 90 weight is way out of the picture.
Shell Dalrina will be hard to find; it's basically like a lithium grease except with clay instead of lithium. I'm sure any marine-grade grease would be fine, or at least that's what I used in mine.
I posted a note over in Don's Synthetics to see what he carries Amsoil wise which might be a good substitute.
Thanks for the replies guys maybe i'll wait and see how mtd snow plow makes out:thThumbsU I'll take a closer look at this weekend.
1 - 11 of 11 Posts
