1 - 2 of 2 Posts
Hi all,
I recently bought a White GT2055. Tractor is in good condition however after using it only a couple times I've noticed the trans fluid has dropped off the full mark and I see a small wet area on the floor under tractor just behind the deck.
I know there is a leak, haven't gotten a chance to investigate yet, just wondered if there is common area/seal that leaks for me to check.
Also, anyone know what kind of fluid to top it off w/? I don't want to mix 2 different kinds and cause an issue....
Thanks,
Ean
It your 2055 is anything like my 1855 that is about where the filter for your hydraulic system is located. Its the same filter as the engine oil filter. You might want to try changing them before you go any farther.
1 - 2 of 2 Posts
