1 - 2 of 2 Posts
mower = craftsmen lawn tractor, 17hp x 42" deck, model # 917.273130
has anyone had a trans axle that leaks gear lube somewhere by the axle as i leaves the trans axle case. i can't find the leak. i have wiped it clean and there isn't any leaking gear lube on the shaft or trans axle. yet there is a little gear lube under the mower? and how do i get to the oil filler plug (gear lube)?
in anticipation, many thanks!
1 - 2 of 2 Posts
