Trans axel fluid
487 Views 10 Replies 6 Participants Last post by  JB_4x4
I have 521613x89a Murray It is a larger tractor. 24 hp 52 inch deck. It is foot pedal hydro. I parked it last summer as trans was acting up and I did not have time to work on it. I did look in the fill hole and whatever fluid is in there looked like chocolate milk. My question is what fluid goes in the transmission/rearend? I have the time to work on it now before
mowing season starts.
Vehicle Tire Automotive tire Wheel Motor vehicle
1 - 11 of 11 Posts
Where did you get that identification information?...I can't find anything on TractorData using that data.......I am pretty sure you can use either type F ATF...or 10W30 Motor Oil
Where did you get that identification information?...I can't find anything on TracorData using that data.......I am pretty sure you can use either type F ATF...or 10W30 Motor Oil
partsandservice.com/bin/ipl.cgi this is a link to a program I got years ago. the tractor had no numbers on it when I got it and after much trial and error, I found this number and use it when I can't find them somewhere else.
Does it tell you what trans is in the machine?
My Wheel Horse is an automatic that uses a pump to drive the tractor and it uses 10W30 this is an older tractor and still has this info on the trans.axel as to what oil to use---Good Luck.
  • Like
Reactions: 1
Husqvarna wants 5W50 full synthetic motor oil in their hydros.
Actually that was a Tuff Torq requirement not Husqvarna.
I left one number off the model number sorry, It is 521613x89A
It is in partstree. It shows the axle, but no part number and lists it as Not available. I will have to look and see if there is any tags or stickers on the axle.
You'll need to ID the transmission itself. The original dealer parts books don't list a transmission model or even a part number for those. It just says to contact the regional distributor for a replacement.
I would call PartsTree and see if they can give you the transaxle manufacturer's name and model number.
  • Like
Reactions: 1
I found a number on the pan of the tractor. It is a Tuff Torq K62 and uses Hy Gard John Deere Hydraulic fluid.
Nice transaxle. Info might help someone in the future.
1 - 11 of 11 Posts
