Back to the o.p.'s request, when I re-wired my small trailer, I used this stuff:
It's really insulated and has held up well for 5+ years in wind/rain/snow/ice.
The only thing I didn't like about it was doing the clearance lights, as it's difficult to make a connection mid-way along the bundle, you either need to cut the wire completely and then butt-join all the wires, or carefully cut out the wire you need, and then butt join some short extensions to get to the light.
If I were doing it again, I would just get 4 plain 14gauge wires of different colors, a heavier gauge black wire (probably 12 gauge) [to run a separate ground instead of using the frame], and plastic split wire loom of the right size to hold the 5 wires, and then run the wires around the frame in a C. Most of the wires end at the taillights, with just the ground and clearance lights continuing on along the other frame rail. For the connections, I would use unshielded crimp butt joints, crimp them, then solder them, then heat shrink tubing over it to keep moisture out.
