1 - 8 of 8 Posts
I have a utility trailer that I use to haul my "stuff" around and decided it needed an upgrade . It originally had the wheelbarrow style tires that always seem to sink in the soft/muddy ground and make the trailer seem unstable . Also , they just didn't seem to be able to handle loads as well as I liked .
So , was finally able to get some 3/4" stock to replace the "axle" that was to short to support the "new" tires . A few cuts and new spacers and was able to mount some tires I had from a scrapped tractor .
Seems to ride better now and handle loads better also without the tires "flattening out" like the old ones . And it also floats across the soft terrain instaed of sinking in .
Good idea.Thought about doing that to my old Red Devil yard cart too. Those skinny pizza cuters are just about worthless!
Camaniac
Yer gonna need some mudflaps now! Good job!
USMC
Looks great and ought to handle a heavy load. slkpk
JD RULES
Great idea and nice set-up , thanks for the picture !!!
Later,x595
15,000 +posts!
Another plus is you now have two spare tires and rims for your wheelbarrow!.
...those whellbarrow tires are like tubes with tread though,even a thorn pops them too easily,IMO--..
I grab any rims from whellbarrow tires I see in the tire pile at the dump and mount 400:480X8" trailer tires or turfs like yours on them and use them on the front of tractors or trailers,hand trucks,etc..being a bit skinnier rim makes the tire beads much less likely to get dislodged or any sticks and other crud wedged between the bead and rim,sort of a poor mans "beadlock"!..
1 - 8 of 8 Posts
