Have a Sears Craftsman LT 11 36. Engine runs and the deck blades spin, but when I engage it in gear, the drive belt won't move. Belt is there and all pulleys move freely by hand. Took trans-axle apart and everything moves freely by hand. When I engage it in gear, it just smokes by the engine pulley because the belt isn't turning, but has tension. Any ideas or suggestions would be appreciated!
Steve59
Have you cbecked your brake. I have had one seize up. Can you take the drive belt off and turn the pully on the rear diff to see if it rotates?
