Ok guys, I have been doing a bunch of reading and found some great ideas. I have been trying to compile all the info on hydraulics as I can, but I have not found all of the things I am curious about. I am hoping there are a few of you out there that can help me out.
Tractor:
I have a mid-late 80's White 1655. I bought it from a coworker who got it from a friend of his father's long ago. Because of that, I am unable to get much of the history of the tractor. I do know it has been hacked up and cobbled together. It has a peerless gear trans on it that does not appear to have come on the tractor originally (the mounting of the axle on the frame is not factory). It has a 16HP Briggs. The clutch setup is basically a jack-shaft mounted horizontally where the belt coming from the vertical shaft engine turns 90 degrees. The clutch moves an idler pulley on the other end of the jack-shaft which goes to the trans. When I got the tractor I had to take apart the jack-shaft and grease up the moving parts. It had some backyard-fabrication done. I got it to work but I became frustrated with the twisting belt popping off from time to time. I think it had to do with the insane amount of flex in the stamped steel frame, but it exposed a problem I wanted a better fix to than just welding in some stiffeners. FYI... The jack-shaft has the same size pulleys on both ends so the trans is not geared down within the jack-shaft assembly.
Old Way:
Proposed New drive System:
I plan on adding hydraulics for a front end loader and possibly a 3 point hitch lift assist and I will need a hydraulic pump for this. I was wondering if I could set the pump up so the shaft ran vertical like the engine and run a motor with the shaft running horizontal to go to the trans pulley. This would get rid of the twisted belt setup and give me smooth control like a hydrostatic. Does anyone see a problem with this setup?
Proposed New Way:
I am already in the process of building a new frame for the tractor out of 2" x 3" x 3/16" tube. Since I plan on adding a front end loader someday, I knew I needed a rock-solid foundation. The frame will be braced as needed.
Questions:
1) Is this just a dumb, money-wasting idea? (if it is please tell me why this is not an idea worth pursuing)
2) If not, what kind of pump size should I be looking for? (keep in mind I would like to run a front end loader on the same pump)
3) Concerning valves, what kind would be best for smooth drive-ability? (I don't want a 100% on-100% off setup)
4) With the pulleys that are on the engine and trans, when the engine is running at full 3600 RPM the trans pulley is running 2630 RPM. Does anyone know what the torque of a 16HP Briggs is at 3600 RPM? I need to find out what kind of output torque the hydraulic motor will need to have.
Sorry this thread is so long, but I am curious as to anybody's ideas on the subject. Thanks!
Tractor:
Old Way:
Proposed New Way:
Questions:
