1 - 3 of 3 Posts
Hey guys thanks for your time. I wanted to know if ouy can put a ford backhoe on a case tractor or a Massey tractor? Are these things interchangeable? Or are all the mounts different? Sorry very new to this.
Generally the mounts from one tractor brand to another are different. Even from one model to another from the same brand can be different. With that being said, as long as the tractor is similar in size to the one that the backhoe came from, it is quite possible that adapters or new mounting brackets could be fabricated to make it work. If the mounting points aren't even close between the 2, then a complete sub-frame could be fabricated, but this would take more time and money, and could end up costing more than finding a good used backhoe that was made for the tractor that you're trying to put it on.
1 - 3 of 3 Posts
