1 - 3 of 3 Posts
OK, I know it's not a Garden tractor but.. I have a Toro GTS that starts on the second pull but stops after the fuel put in by squeezing the ball runs out. If I hold the squeeze ball in a little it will stay running. I have a new air filter, new fuel, fresh plug. Any thoughts?:banghead3 :banghead3
A friends lawn mower had the same problem. The cause was water in the float bowl. That could be your problem if your carb is similar.
I fixed it..Drained the bowl, the float was stuck so I cleaned and lubed the carb. That's what happens with only using it 4 times a year I guess. Works like new now. Thanks glurg
1 - 3 of 3 Posts
