Hi all! Excited to become a part of the tractor forum! I recently inherited an LT1000 from a friend who got a brand new J.D. tractor. I bought a snow blade attachment, and after mulching up some last minute leaves took the mower deck off to get ready for winter and put on the snow blade.
This is my first tractor, and the first time I personally have removed the deck. Now that the deck is removed, the tractor won't start (turn the key, absolutely nothing happens). Tried a new battery just in case, and it's filled with gas.
I thought I would ask here first in case there might be something obvious to check, or possibly a common problem/simple fix, before I haul it somewhere to get looked at.
There was a cable loose after I removed the deck, which I'm pretty sure is the attachment clutch (which I thought I was supposed to remove).
Also, while looking around for anything obvious, there seems to be a loose pin on the "gear shifter" not attached to anything.
I'll attach some pic's pf the loose cable, unattached pin, and the mower deck that I removed.
Any advice would be much appreciated! I want to get it up and running again soon.
