The homemade tabs look plenty beefy - the only weak point I see is the angle iron rails used as the push frame on the plow - particularly in between the front brace and the rear brace/mounting tab.
Well some dozer blades do have trip springs, my 46" dozer blade does but you can lock them out so its solid. Cant remember what number it is. Would have to look.The Sears dozer blades don't have a trip feature with springs. You have to be careful about how fast you go if there is the chance of hitting anything unmovable.
LEE,The Sears dozer blades don't have a trip feature with springs. You have to be careful about how fast you go if there is the chance of hitting anything unmovable.
The advantage of the snow thrower is that you move the snow just one time! After that, it's gone from your thoughts.Some people plow the snow until it starts to really pile up. Then they use a loader to scoop up the big piles and stock pile the snow in a place where it is out of the way. I have also seen people use just the loader to move the snow.
A snow thower throws the snow a longer distance away from the tractor if the discharge snorkle is pointed just right.
The disadvantage of using a snow blower/thrower is that you need a place to blow the snow. I have a 60' long x 27' wide stretch of driveway between 2 houses with a garage at the end of one driveway and a continuation at the end of the other. Most throwers/blowers will have to handle the snow 2, 3, and sometimes 4 times to clear that zone, and the options for where it lands aren't good.The advantage of the snow thrower is that you move the snow just one time! After that, it's gone from your thoughts.
Everytime you plow with a blade, you might be moving it into the track of the next pass where you will move it again (and again, and again, . . . :sidelaugh:sidelaugh)
Maybe it's just a case of terminology. I would call a blade that does not trip a dozer blade, and one that does a snow blade.Well some dozer blades do have trip springs, my 46" dozer blade does but you can lock them out so its solid. Cant remember what number it is. Would have to look.
:ditto:Maybe it's just a case of terminology. I would call a blade that does not trip a dozer blade, and one that does a snow blade.
917.25311 that's the same one I have-Well some dozer blades do have trip springs, my 46" dozer blade does but you can lock them out so its solid. Cant remember what number it is. Would have to look.
Mine is 917.253311. Im guessing thats what you meant?917.25311 that's the same one I have-
yepMine is 917.253311. Im guessing thats what you meant?
Im gonna be spreadin alot of gravel and dirt in the spring with mine, we will see if it holds up in stock form or not lol. But I see your point.Maybe it's just a case of terminology. I would call a blade that does not trip a dozer blade, and one that does a snow blade.
In any case, his does not trip.
Around here, I have to be careful making my trails for snow removal across the grass with the first couple of snowfalls. Even if the ground is frozen before the first snow, it thaws out with the blanket of insulating snow and I can easily peel the sod. Once the trails are established, the frost gets into the turf and I can put down pressure on the cutting edge with little damage to the grass. Just don't get off the trail or you get stuck.How bad is the digging on an FEL? Would it scrape off a layer of grass if you went past the edge of the cement driveway? Would it dig a fair trench if you're not careful?
