Do the Sears loaders typically have a "float" position on the bucket lift?
I have plowed with the loader on my backhoe - you can't scrape down to the dirt until the ground is completely frozen or you will end up with half the driveway in the bucket, yes. Once it is frozen, though, I found it works well to drop the bucket down and let it float, then curl forward to get the desired amount of scraping action.
Using a plow is quicker, but you end up with snowbanks that crowd in as the winter goes on.
If you have both, you can use the plow to quickly open the driveway up then use the loader to bucket back the banks every so often when you have more time to spend.
I've found that a 2-stage snow blower is the best of both worlds - fast, and throws the snow well out of the way. Only drawback is the rocks and dirt you stir up before the ground freezes. I usually try to let the first storm or two pack down if they aren't too deep and that helps as long as you don't get a weird winter like we've had so far.
