1 - 6 of 6 Posts
Have a 2006 2305 with about 430 hours, this machine does anything asked of it no problem there.:greendr:
I notices while doing my monthly waxing that the front tires are wearing uneven both on the outside, is this normal or can the front end be adjusted?
I do have it in 4 wheel drive 90% of the time because of the hills. :thanku:
9K+ Poster
Curly,
I replaced my front tires on my 2210 at about 400 hrs. I do a fair amount of driving on paved roads though.
USMC
4WD will wear on tires quicker than 2WD. How is the toe in? slkpk
I think that's the problem they are worn on the outside only. They still have plenty of rubber on them, just wondering if it worth playing with the toe in -out or if it's just normal since I have it in 4WD most of the time.
USMC
Just curious why you have it in 4WD most of the time. slkpk
Live in western part of NC in the mountains and everything is a hill. If the grass is the least bit wet I slide every which way. If I'm not cutting grass I'm moving dirt.
It's actually more of a hill then it looks.
1 - 6 of 6 Posts
