I have a 1996 Craftsman GT I parked in the shed 4 years ago. I've decided to try to get it running again to use on an "up north" property just to mow field type grass. All the tires were flat and off the bead. I managed to get them re inflated so I could pull it out of the shed and into the garage for a once over.
3 of the 4 tires are flat again.
I don't want to spend $ on tires if I can't get t his thing to run again, and to get it to run, I gotta roll it around.
Question: Has anyone had any luck using tire sealer in can or bottles? :tango_face_surprise I know, it makes a mess but this would likely be temporary fix just to keep aired up while I tinker with the engine and transmission. If I can't get it running, it becomes junk pile machine or parted out anyway.
Thoughts and experiences?
