Chains should be tight. Pressure should be at or below normal recommended pressure. Many use lower pressure to get a better grip on the ground.
Chains if installed correctly and tight should not come loose. Check out peerless chain installation instructions or post some pictures. Many here can help.
A common mistake occurs in how the outer link is attached.
