Now I finally have got some time to put the Volvo BM Mini together and begun today with a going through what needs to be done.
- Oil change to both engine and transaxle and greasing every moving point is obvious.
- Trans also seem not to be 100 sealed, a tightening of bolts will be the first try.
- A new fuel line is needed.
- Exhaust system is deficient home made from plumber pipes and totally worn-out.
- Electricity needs attention, as two cable ends hang loose underneath and battery is missing. Earth twist and plus powerline to/from battery to be renewed.
- Right front tyre needs refilling every day it will be used as pressure seeps out.
- Steering needs attention as one rod end plays and another nut is loose.
- Brake connection rod is missing but is present on the parts unit, so relatively easily solved.
But after the examination I devoted myself to mowing deck installation. As the original deck (36" I think) misses parts and shows signs of wear I have a few months back spent a little time searching for a replacement, which resulted in a much newer 48" unit from a Jonsered 19 hp GT.
(the shed is really a shame, I know...)
After a bit of try the deck found its new place. It looks a bit heavy with such a large deck on such a small tractor and I calmly wish this finally will work.
Now the task is to find the belt path as the original deck has horisontal axle connected to angle gears and the new is all vertical. I will weld kind of a front bumper of to install idler pulleys as mule drive, but it will be a very tight fit as steering rods are in the way. Maybe the mule drive will get the wheels rather far down low and kick up idler pulleys added a bit behind the steering rods to gain space. To be sorted out.
Hopefully continued in the next few days.
