Greetings,
Thought you guys should see this.....posted over in the Kubota forum but...
This could also be a testimate to foam in tires as this sucker was still going just like this.......The tread is missing over a large part of the tire and over a square foot of foam showing next to it where it was already worn off. The 4 wheel drive on Kubotas really pull so once you tear a lug off a tire, it doesn't take long..
It was only used as needed until new tires came in but hauled a 1600 pound pallet on a set of bucket forks two weeks ago and was used to dig, then cover an electric and water line to an RV hookup for my bus. Here they are along with the new 8 ply replacements in the truck for delivery to the tire place. A shop in Austin will do the dirty deed, cutting the old tires and foam cores off the rims, installing new tires, inflating and letting set for a while, then filling with foam. They only foam on Tuesday and Friday and have to prep them so I am hoping to get them in early tomorrow morning and pick up later this week.
We only use the most modern hydraulic jacks for tire removal....yeah, don't worry, I will put a chunk of soft 4 x 12 under each side and let it down gently...while waiting on the tires/rims to come back.
