1 - 8 of 8 Posts
Electrician
Does it look like mine in this picture? You can get that at Tractor Supply or possibly Farm & Fleet. I can measure the diameter for you if you need.
My tiller had a 3/4''- 10 spline shaft input and came with a 10 spline - 6'' dia. pulley. is that what you are looking for?
Power King
Went to TSC today and picked up a pulley. It is the one with the weld in center hub. The hub is too long for the shaft so I will have to grind some steel off before I weld it up. Mine is a 6 inch with a 3/4 shaft with a 3/16 key way.
Electrician
Look at the top picture in this attachment. You will also need the hitch blocks for your tractor if you don't already have them. I can post a pic of that too if you need it.
Electrician
That didn't come out too good. I'll go out and take photos of mine tomorrow morning and post them. That will be much better.:praying:
Electrician
Here are some pics. The rear lift links simply attach to your lift arms.
1 - 8 of 8 Posts
