tiller compatibility
1293 Views 5 Replies 3 Participants Last post by  timflury
will a 36" tiller for a 2110 fit my 7117?
1 - 6 of 6 Posts
Well, probably . Most or all of the 36" tillers will 'fit' you rmachine, but it would depend on the model # whether or not you need certain pulley sets or PTO's to operate it.
Early versions may require a PTO setup that is not compatible with your machine. Later models have a two pulley setup on a small bracket that keeps your belts tensioned and aligned. Most times, half the battle is having the pulley sets with the tiller. Often, they sell without them, creating a headache or rendering the tiller useless.
I believe all 36" Simplicity Soverign and Landlord tillers will pin up to your tractor and lift...I cannot speak to anything built after the early '80's and know the 4, 5 & 6000 series tillers have different hitching.
These should be sure shots:
1690287
1690039
990694
990545
990503
http://www.simpletractors.com/what_fits/rotary_tillers.htm
Look in here. Make sure you have your model number(s) handy.
There most likely will be a different drive setup like TMG mentioned.
1 - 6 of 6 Posts
