Picked up this nice TB Horse last week for a steel. It's in need of some TLC and some restoration but I think I can handle it if I can find some parts.
According to the sticky in this section I think it's a Horse II made around 1979-80. Serial # is 454005 and corresponds to around that date and the stamp on the bars says 10/25/1979
The previous owner passed away so it had to go. Here's some history!
PO found some issues with it and decided to install some new parts, including a Brand New B&S 6.5Hp intek engine with get this, 10mins on it. Apparently after installing the engine and rear worm gear, bearings and seals the shaft bearing was missed and there was too much play, so upon reassembly and testing ( that's why it only ran 10mins) discovered the tines wouldn't move when trying to till the ground. He took it apart and found the newly installed worm gear warn. Little while later he passed away and this is how it sits. I picked it up from his wife when she was cleaning out the garage the way it sat. It looks to be all there but I think I'll tear into it over the next while and see what it needs but safe to say some new bearings, seals, worm gear ( if I can find it still ) and whatever it needs to restore it back working again.
Here's some pics..
Here is the old and new worm gear..
The old shaft was worn where the seal rubbed on it. New shaft is excellent as are the bearings but the main shaft bearing is in peaces in the containers. I think it's a Timken bearing LM11949..
The tines and hood are there as well as the depth bar.
So, what ya'll think?
Here's some pics..
