1 - 10 of 10 Posts
Found this on another forum and thought some of you guys might enjoy reading this.:)
Anatomy of a Top Fuel Run
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F. (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined)
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
A Top Fuel dragster accelerates from 0 to 100 mph in as little as .8 seconds, subjecting the driver to a force about 5.7 times their weight. This acceleration takes less than a tenth of the time needed by a production Porsche 911 Turbo to reach the same speed. A top fuel dragster can exceed 280 mph in just 660 feet.
Top fuel engines turn approximately 540 revolutions from light to light. Including the burnout, the engine must only survive 900 revolutions under load.
The motor’s redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona, CA). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron, OH).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course…
... and that my friend, is ACCELERATION!
At top engine speed, the exhaust gases escaping from the open headers produce about 800-1000 lbs. downforce. The massive foil over and behind the rear wheels produces much more downforce, peaking at around 12,000 lb when the car reaches a speed of about 325 mph (523 km/h).
They generate 120 dB of noise,[1] enough to cause some peoples' eardrums physical pain. This is louder than a Boeing 747 jet airliner at take-off power.
Measuring the power output of a top fuel engine directly is not feasible. This is not, as is sometimes stated, because no dynamometer exists that can measure the output of a Top Fuel engine; in reality, dynamometers capable of measuring tens of thousands of horsepower at the appropriate shaft speeds are in widespread use. Rather, it is because a Top Fuel engine cannot be run at its maximum power output for more than about 10 seconds at a time without overheating (or perhaps exploding) as would be necessary to take a reliable power reading. Instead, the power output of the engine is usually calculated based upon the car's weight and its performance.
· I'll never get to 10,000
That cool!
However, I'll stick with my stock 8HP..it'll do the 1/4 mile in about 2 minutes. :fing32:
· 20,000 +posts!
A good read,but take a RIDE in one,if you REALLY want to know what its like!..:eek:...
I had a "half speed" test run once in a nitro funny car,and after the run down the track at "only" 155 mph,I was barely able to keep my lunch down till we got back to the pits!..felt like my stomach stayed at the starting line,and STAYED there!..and what a RUSH,to go from a standstill to 155 mph in about 4 seconds..even my first jet plane ride didn't feel THAT scary!..made booting the 4 bbl in my GTO feel like it had a Briggs and Stratton under the hood!--I can only imagine what a full bore run feel like in one..
Sweet,
For the average joe to get a taste go to Cedar Point and checkout the topfuel coaster 0-120mph in 4 sec .
Get ready for the ride of your life. This amazing speed machine is one of the tallest and fastest roller coasters on Earth. Climb aboard unique dragster-style trains and inch forward to the starting line. The engine revs. Your heart pumps. The tree lights count down to green and you're launched to speeds of 120 mph in less than 4 seconds.
The ride's just getting started as you climb 420 feet into the air, crest a massive hill and spiral 270 degrees as you speed towards the finish line. The entire experience is over in 17 seconds.
Sweet,
I havent been in a few years but here is a video of the Top Thrill Dragster at Cedar Point:
http://www.youtube.com/watch?v=VPjN7zArwiI
1 - 10 of 10 Posts
