Hey Gang!
It looks like I bought a bad coil on E-bay. Here is the story...tell me if I'm missing something.
I have a Tecumseh HH140 (overhead valve) in a 1973 Bolens G14. It ran fine up until a couple of weeks ago, then suddenly had no spark.
I disconnected the 3-wire harness from the tractor to isolate the engine from the tractor circuit. The flywheel trigger pins and the air gap (.008 inch) are good. I even removed the spark plug boot to check for spark directly from the high tension wire. I pulled the flywheel to check the magnets and keyway and everything seems to be in order there.
Based on the above actions, I figured that the coil had gone bad. E-bay to the rescue with a used coil for $81 and---you guessed it---still no spark.
I measured the resistance on both coils and these are the results. Perhaps someone can make some analysis of these numbers.
ORIGINAL COIL
Engine ground to Ground Terminal: Open
Ground Terminal to High Tension Lead: Open
High Tension Lead to Engine Ground: 5.08 K
E-BAY COIL
Engine ground to Ground Terminal: 3.8 M
High Tension Lead to Engine Ground: 5.45 K
Am I missing something? It seems pretty simple...rotating magnets past the coil and it is supposed to spark. Anybody have any other ideas?
Thanks!
ORIGINAL COIL
E-BAY COIL
Thanks!
