1 - 3 of 3 Posts
Hi All, I have a Tecumseh H70 engine with a lighting coil/ charging system it has a diode system to convert to DC for charging the Battery. My luck is that one of the diodes is gone anyone know where a replacement maybe be gotten? If I can't locate an original I'll have to adapt a diode to the set up but would prefer to find an OEM diode.
Thanks GB in MN
20,000 +posts!
I dont know if you'll have any luck finding an OEM diode,but you might be able to use one from an altenator in place of it..auto parts stores sell them,might not have them right in stock though,but they can order one for you..or you can rob one from a used one..
Hi tractor-holic, my research has come with that the OEM's are no longer available, but I did find a great diagram of how to solder in replacement doides along with the p/n of that diode. Thanks
GB in MN
1 - 3 of 3 Posts
