Problem with using photo tachs is where is the correct place to put the reflective tape to be fully accurate?
I myself know a car engines timing mark is on the outer edge of the flywheel so I placed it there on my Kohler too. I searched pretty good for the original timing mark on my K241 and never found an actual mark anywhere? Never tangled with my other horses RPM?
How to vids on photo tachs I saw people put the tape in center/outer both on flywheels/pulleys while using this type of tach testing everything, I do mean "Everdamnthing" too..:00000060:
They don't know it changes RPM readings so drastically depending where one places sticker and where the factory intends or would intend it to be when checked using this method. Guess they'll learn that with a booom huh?
Also' what size flywheel/balancer is now being used vs was originally used on an engine matters. It can all change the RPM from factory is my point here, so one needs to know what they actually have in front of them if placing your own mark anywhere you want it on the old stuff.
fwiw- My guess was anywhere on the outer edge of my flywheel but where is the Kohler factory mark on K/Magnum series? Very odd to me if there just isn't one at all but seems to be no timing mark on neither of my Kohlers?
I had no other Kohler to compare settings to (back then) nor did I know if the governor/Carb was still set to OEM standards? Being both my tractors were bought used I still don't know how close they really are to factory RPM settings. Planned on buying a tiny tach, just never did it. Its been several yrs ago though and nothings blown apart yet..:tango_face_grin:
Thanks...
