Ford 2000; 3 cyl. gas; 4/1 trans....I got tired of having to wire up my sway bars when changing implements, or them getting in the way, so rigged up the hanger seen in the photo to hold the bars up and out of the way. Once an implement is on the hitch, the S-hook hooked in the clevis gets hooked in the eye bolted to the fender and the sway bar gets put on the hitch pins. Painted the ends of the sway bars yellow so I can see them if they are in the dirt. So far, this has worked very well and I haven't yet backed up onto a sway bar. Your mileage may vary.
