I finally got my fuel delivery issues straightened out by adding the electric fuel pump but now the tractor will cut out and loose power randomly. What I mean is it looses electrical power, the fuel gauge cuts out along with all other dash lights, it sputters and quits then will not restart. I looked over the electrical system and found a burnt connector at the regulator/rectifier. the connector that was burnt was one of the AC lines coming from the 15 amp stator.
My question is, could the regulator be causing the electrical system to fail?
I disconnected the regulator and the tractor runs fine until the battery goes dead.
When i get the chance I will run tests on the regulator and stator too see if they are good or bad but right now I'm puzzled as to why it will run fine for an hour or so then just act up and quit.
