1 - 2 of 2 Posts
Hi all,
I have a recently purchased 20 hp SunStar with a Kohler Magnum 20 twin. Hydrostatic. Great little tractor.
However, I cant get it into high gear. The hi-low speed control just wont move forward, it will move upward until it hits the edge of the housing, and in that position it is in neutral, but it wont go forward and around the housing to get into high.
It tends to creep a little in neutral. Thinkiing this might have somehting to do with it, I have spent some time wiggling the ground-speed control and trying the hi-low. no success.
That problem has been with me since i bought the tractor.
The other problem is that it keeps dieing when i rev it much past idle. This just started. I have used the tractor to till some ground and i had it at full revs during that with no problem. the air-cleaner is not the problem (still happens with air-cleaner removed).
Any thoughts on either problem?
Discussion Starter #2
is this maybe not the right place to post this kind of question? i see that 21 people have looked at my post, but nobody has posted any replies.
1 - 2 of 2 Posts
