Have you corrected the leak mentioned at the start of the thread? Does the transmission work?
Thanks for checking in. I freed up the check valve plungers, and that stopped the leak, but the tractor still wouldn't move nor the hydraulics work (see post #4). It was at that point, the charge pump drive pin became suspect, which turned out to be ok.
I'm at a crossroads, now - do I re-install the driveshaft and do some pressure testing, or are there things to look at
before I re-install the driveshaft? For example, when removing the charge pump, the outgoing implement line was just a smidge in the way, so I disconnected it - I was expecting fluid (or some evidence of it), but looking back, it seemed dry. Is that a clue? The implement check valve didn't seem dry and the pin seemed to be able to move freely. The charge check valve seemed ok as well. I suppose the filter could be clogged, but it's a brand new Wix hydraulic filter. Worst case, I suppose, is that the pump itself is toast.
