1 - 10 of 10 Posts
Need some help... Last year the dry-rotted front tires were replaced and documented on this forum and YouTube..
It's now time to upgrade the rear tires. Factory rear size on my John Deere 265 is 23x10.50-12. My property is very hilly and defiantly need much more traction than what the dry-rotted rear factory tires offer. Options are limited in this size, either the Carlisle Tru Power or Carlisle All Trail. I'm not opposed to going with a different size tire for more options, but don't know what size would work. Any suggestions would be appreciated and will document like the fronts!
Anyone know what the largest tire could run, without modifications? Also the 10.5 rim width, would it accommodate a 12 width tire?
Diesels are awesome!
With a stock 10.5" wide tire, it would be an 8.5" wide rim. It would still most likely fit a 26-12-12, but it might hit the inside of the fender or the frame/brake linkage.
Well, I'm about to pull the trigger on ordering a set of 26x12x12 Tru Powers for the rear of my 265. The cost for the bigger size is only about $30 more. Fingers crossed I won't have to trim the rear fenders for a fit. I don't see anything else that would hinder an additional 1.5 inches of clearance. The wider 12 inch tire vs the stock 10.50 mounted on a 8.5 wheel should balloon a bit so I hope this helps negotiate clearance issues.
...just fyi, this is a 7 year old thread and deerejohn265 hasn't logged into the site since 2016...you are unlikely to get a response from that user.
His avatar picture looks like they fit, but they do look tight!
1 - 10 of 10 Posts
