I purchased my first Suburban tractor last week and I noticed that Sears no longer has a part listing for the blades for the 42" mower deck (917.253580). Does anybody have any suggestions for a source for appropriate blades for this deck?
The Suburban 42" decks has 14 9/16" long blades ( takes 3) that went on the 42" deck. Check up in the sponsers section under Midwest Mower, one of the member posted last month buying new blades from them for his 42" suburban deck.I need new bladeds but im not sure of the width of my deck. Where do i measure it to determine the size. the current blades are 14 1/4 wide. I also need to know the length of the belt inside the deck. The one i measured at 91".
Thanks
Wow, you brought up a 3 year old thread. If it should turn out that you have a 42" suburban deck I think these will be your cheapest, Prime line.I need new bladeds but im not sure of the width of my deck. Where do i measure it to determine the size. the current blades are 14 1/4 wide. I also need to know the length of the belt inside the deck. The one i measured at 91".
Thanks
