STX38, Yellow Deck, Manual Transmission-
Getting close now, things almost 100% well let's be honest, closer to 90... but making progress
1) Is there a process for changing or at least checking the lubricant in the transaxel?
2) Out at the ends of the axels are grease zerks. I put the gun on them and put a few good pumps into them. How do I know when enough is enough? Usually you stop when the zerk takes no more but I want to be sure, because it seems like an empty pit! (I checked nothing is leaking out...)
thanks!
Certified Master Tinkerer
If it is the same as 100 series gear drives I believe the transaxle is sealed so there is no way to change it without disassembly. I'd start with where you are on grease and maybe hit again after a few hours of running when the new grease has redistributed.
thank you!
I do think the tranaxel is sealed, jusat wasn;t sure if there was something up near the neutral switch that I could not see.
And I agree on the grease, just seemed liek it was taking a lot, wanted to be sure it wasn't going where it shoudn't.
:trink40:
youll spend a fortune pumping grease to those zerks,those are just for the axle bushings,it is a sealed case,u have to split to check,it's really not that big of job, just give them 5 or six pumps and call it good
