1 - 10 of 10 Posts
I took removed the yellow deck off my tractor for the first time to repair a pulley, and now am jhaving a dificult time re-installing it. I have the owners manual, but it isn't clear. It tells me to use the rear holes on the front bracket. The issue is there are two holes on the mower support, and two holes on the tractor. I should have taken pictures before I removed it, but didn't. Any hints, or tips to make it easier? It is a real PITA. getting the rear levers to line up, and still wiggle the deck enough to makwe the front supports fit. Thanks in advance.
I have the black deck, not sure if they match up. I'll try to get some pictures of it though so you can see what it looks like. I just had it off to redo the drive belt. Not too bad to get it back on, but there are some braces that it was hard to set, had to have help holding the deck up while I put the bolt in.
Did you ever get your deck back on? I've got some pics of my yellow deck at home. If you need them just let me know and I'll post them here. I've had the deck off a couple of times to replace and idler spring and a drive belt. I took a few pics while I was doing it.
Hi Tony,
Any chance you still have those pictures? I took mine off to clean up the pullys but failed to take pics of my own.
Thanks,
1 - 10 of 10 Posts
