Hi,
First time poster here looking for some advice. I purchased a "beater" STX38 at the beginning of the summer for 200 bucks hoping it would get me through til the prices came down in the fall and I might make a more long term investment. Well, the **** thing ran like a champ all summer and I just might keep it. That was until last week.....
It is the black deck, 13hp, hydro version, by the way. The seat switch was by passed when I bought (actually, the entire seat was missing), but both the brake and PTO switched operated correctly.
It always started first crank. When I started it last week, I was distracted and flooded the engine. Rather than wait, I kept cranking and it finally started, and I mowed half the lawn. When I tried to restart it a little later, just got a click from the solenoid. After about a hundred tries, it cranked, started, and I started mowing. After about 20 minutes, it stalled, and another hundred key turns to get it started. Here is where it gets interesting....
As soon as I took my foot off the brake, it died. If I leave the brake on and engage the PTO, it dies. Leave the brake on and the PTO off, it will idle for hours. I can catch the engine from dying by quickly depressing the brake or turning the PTO off.
Since I cranked it so heavily trying to start after I flooded it, I think I burned out some switch or maybe the solenoid. What I don't understand is why both the brake safety AND the PTO safety are BOTH killing the engine - are they wired together? In a normal machine, can the PTO be engaged with the brake on?
Any thoughts on what I should replace? Could the prolonged cranking when it was flooded have burned a wire from high amps? Or is this just a bad solenoid that had a safety switch go south too?
Thanks,
Lou
Thanks,
Lou
