1 - 7 of 7 Posts
I am working on my Dad's STX30 12hp with a yellow deck. The engine does not smoke, but it has almost no power. The Kohler manual says with a CV12.5 engine it is difficult to check the compression accurately because of the compression release.
I starts fine, and runs smooth. How would I go about finding out why it has a loss of power?
Diesels are awesome!
Usually, the air filter is clogged or maybe something with the governor.
Air filter is clean. I had thought about the governor, I'll look in the manual to try to figure out how it works. I seem to remember the smaller Briggs engines had a plastic flap.
Briggs engines are a little bit of a PITA with the fuel system. The governor is most likely your problem since the air filter isn't.
It looks like it is rings. I checked the compression, it was 60. I put oil in the spark hole hole, it went to 100.
Anyone know how hard it is to pull the engine?
It may not be rings. It could be the head gasket. A cheap part to replace and pulling the head off isn't too bad a job.
Sorry about the late reply. It turns out it was the throttle plate in the carb slipping on the shaft.
A friend of mine figured it out. He had seen it before. The new shaft I ordered was a different design, so I don't think it will happen again.
1 - 7 of 7 Posts
