And Littletractorguy for posting the link to Brad's original post....I was experiencing what seems to be a typical problem with this line of tractors in which the starter switch is engaged and just a "click" response from the tractor....Brad had posted a solution back in 2009 (https://www.mytractorforum.com/215-...-section/95701-stx38-starter-problem-fix.html) it was very easy and less than $10 to do....I do have some wire and solder less wire connectors laying around, so I did not have to go and buy that...it was $3.50 for the relay and $3.50 for an in line fuse holder...the relay is just a 12V 40 amp relay "for adding auxiliary lighting or horns"...Brad's instructions show which of the numbered terminals on the relay go to what existing wiring and terminal points on your tractor
