Send a msg to Bear; he is the MM man here.
Exactly::: you would be suprized..how much frozen water can do ..just dripping in around shifter boot...B,Cdn.Country Bumkin said:Are you sure it"s the brakes. maybe water in the trans or rearend frozen?
Archie
Do you have any plans next week end? sounds your a bit handier than I when it comes to tractors, but thanks for another area to consider...Byron R said:When I tryed moving mine it was not brakes it was locked gears..I removed shifter plate inspection cover and shimed gears to unlock trans...this was a JD 40..are you sure its the brakes..it had been 30 yrs..on mine..B,
Yes Glen, I finaly foung a great guy to transport it and bingo, The Tractor didnt want to come to his new home. I dont think he realizes how well I will treat him. He is like a stubborn Mule. Now Iam determined more than ever to get this rusted iron up and running. Either the ground is to soft or the tractor is frozen, I cant win...glenn27 said:Shawn--is this the tractor up in N.Y. that we talked about a couple weeks ago? I think you replyed you found someone to transport it for you?
